After coming across a post the other week about the high speed cut out, I decided to try what they had discussed. I cut the wire on the firewall. Since then I have no speedo/odometer. Is this normal? Will it cause any problems? I noticed someone mentioned about putting a toggle switch in-line. I guess that is so you can cut it off when you feel like it. Anyway I just want to make sure I did it right. Thanks for any help.
