i have a problem i can not figure out. i have recently installed a edge comp box. prior to the comp, i was running a diablo powerpuck. the truck ran great with the puck, but after installing the comp box it cuts out like it is starving for fuel. it will do it in any level, even if the box is turned off. installed fass 150 fuel system and still same problem. had dodge dealership check codes, and there were none. i called edge and they sent me a new box and harness, and still same problem. i then disconnected the wire going to the pump thinking i had a weak vp44, but it still acted up. removed the comp harness and box and runs normal. could this problem be a map sensor even if there is no codes and no check engine light. truck is a 2002 with little over 50,000 miles. please help
