Cylinder Head Torque
Tow hooks on 2002
Why not use blow off valves??
After replacing my head gasket it was recommended that I re-torque the head bolts. How do you do this when the shop manual says torque value plus 90 degrees. and does not say anything about re-torque. ?
You don't.
I torque them to about 120 ft lb in several steps, following the factory specified sequence for each step. I tried retorquing the first time I changed a head, and the torque stayed good on all the bolts. the Dodge manual does not mention retorquing.
