Details here: TDR Privileges
When they increased the displacement, did they bore it, stroke it or both? If they just increased the stroke, shouldn't be to much different I would think.
from what I have read the entire block has been retooled. the bore and stroke are slightly larger than our 5. 9's and the cylinders apparently are siamesed 1-2 3-4 5-6.
I see what you are getting at, however I doubt it will work.
no they are not, the injectors are different, fuel supply tubes are different, they are close, bu you cannot swap them, if i think that is what your getting at.
