D-350 Rear Wheel Width
Injector pump leak
Cooling system pushing out coolant
Can someone tell me how wide a 1993 D-350 is at the rear wheels? I need to haul one from Texas to Florida and need to see how wide of a trailer I need.
I measured my sons and posted it a few weeks ago... . search the archives... too freakin' cold to go out tonight and measure again!!!!
Jay
Thanks I did look it up and you had said 93". That helps. One more question though, do the front wheels line up with the outside duals or the inside or are they the same width as the single wheels I have on my D-250? I could remove the outside rear tires to transport it if the front wheels and the inside rears will fit. Thanks again jleonard,
Roy
Originally posted by rlyons
One more question though, do the front wheels line up with the outside duals or the inside or are they the same width as the single wheels I have on my D-250? Roy [/B]
Oops, hit the submit button by mistake!
The fronts don't line up with either rear--inside rear will be inboard of fronts, outside rear way outside of fronts. You'll have to take the outer wheel off. Front tires s/b about 77" wide.
Scott
wrecked truck
I am changing from automatic to a manual on my 92. Will you have any parts from the wrecked truck that would help my project. I am located in south Georgia.
Thanks
1stgen4evr
James
