d p f sensor connectors
Texas Friends
05-g56 in an 09
If some one was going to buy a smarty junior and a d p f delete pipe, what do you do with the wire sensor connectors. is there connecter plugs you can use or what did you do.
Any other advice would be greatly appreciated as in what to be aware of? I read somewhere something about a transmission wire connector.
The pressure differential sensor should stay plugged in, with a hose looped between the two ports. The rest of the plugs just hang - wrap tape around the ends if you want.
