Dam those compression fittings!!!
EGT Probe, Drilling Exhaust Manifold
Explain "npt" to me (ie 1/8 npt, etc...)
Well, i'm half-way done installing my boost/egt guage. . half-way because i dropped the compression collar (which goes around the nylon tube) and it is lost! Anybody know where I can find one of these? I mean, is this just a guage thing or are the collars used in other applications.
help!
'01 Eth 3500 dually, no mods planned except maybe an amsoil filter & guages. See My Truck and also be sure to read What tools & methods to use for an easy 1st oil change!!!
"Be happy you don't get all the government you pay for. " -W. C. Fields
Check out the nearest hardware store. It probably is a stock item.
Joe George
Eureka, CA
'95 2500 CC auto 4X4,3. 54,Combo EGT/boost guage,custom switch panel,PacBrake,TST #5,BD valve body,Automatic motorhome steps on both sides,Foldacover hard bed cover,Cummins chrome kit,Black steel grill guard,Front hitch receiver
dmurdock
I did the same thing you did. Home Depot or Lowes won't have an 1/8". Smallest they go to is 1/4". I thought I was out of luck and would have too spring for a pressure gauge installation kit, just to get the ferrule.
I found mine at NAPA. They had a whole box behind the counter. You need an 1/8" ferrule. About 25 cents a piece. Get 2 or 3.
Ever try to unscrew a compression fitting and try to reuse the ferrule? No way. Its too distorted. Have an extra collar around incase you get a kink and need to cut back the tubing.
[This message has been edited by HEMI®Dart (edited 02-02-2001). ]
Dmurdock
Try Parts Connection on 183 in Cedar Park.
Tom should be able to help you, if you are unable to locate any you can page me, I have a few and am in Georgetown.
Dean
512-907-3948
Ace-is the place. . 09 cheap
I just put transmission sender in with comp fitting Pain in the A$$, Spend the money on the DC part.
I FUBAR'd one of of the ferrules when I installed the gauges on my 96 but it seemed to seal so I didn't replace it. When I put them in my 01. 5 I went to a Parker distributor to get another fitting and a fitting to go into that 3/4 NPT port. They have a fitting called a Prestolok II that you use with the Parflex tubing that came with my ISSPRO Gauge. These fittings use a lockring to retaing the tubing and an o-ring to seal. All you do is push the tubing into the fitting and that's it. Supposed to be good for 150 PSI. I'm sure other suppliers make something comparable. This made for a very easy install.
Darren
2001. 5 2500 4X4 SLT, ETH/DEE, Amsoil Bypass Filtration, Mag-Hytec w/Amsoil, Walker 21468, Passenger Side Grab Handle That DC No Longer Installs as of 7-00, Michael Brolin CB Mount, 14K@013101, ICQ: 103247365, IM: xxtreme223
Thanks for the hints. . got everything installed and it works! Yes, tom at the parts connection had the ferrules.
-dm
OH YES, forgot to mention, of course i found the one i dropped when i was putting my tools up... . #ad
[This message has been edited by dmurdock (edited 02-03-2001). ]
