Engine/Transmission (1994 - 1998) Damn Transmission!!!
Ok here goes I had my transmission rebuilt a wile back and it was working just fine untill I brought it back to the place because it was not fully engaging in 1st gear when I would take off from a dead stop, unless I manually put it in first gear. He said it had to do with the line pressures and he adjusted the TV cable. Now something else it is doing is when I put in drive it will first partially engage then fully engage in 1st gear. Now I know thats not normal but my question is a two part one:
1. What would cause that dubble pumping engagement problem??
2. The truck will now not shift into OD untill 50mph and I wanna know how to adjust the TV cable to get it to shift at 45mph or so???
Thanks, Travis
Call Dave Goerend 563 778 2719
Tell him what your problem and he will have a correct answer for you. We don't know anything about the people that did your transmission. Dave is the man!
