First of all, make sure you do not have a lower ball joint going bad on the right side. Second, remove the 4 bolts that hold the shift fork onto the axle housing, which is on back of the passenger side. At each end of the fork, there should be a pad that fits into a groove. If this pads get brittle, they can break off and will not shift the collar onto the inner axle shaft far enough.
