2nd Gen Non-Engine/Transmission Dana 70 rear differential
2nd Gen Non-Engine/Transmission drum to disc conversion
2nd Gen Non-Engine/Transmission Good Alignment Shop in CT
Does anyone know what the torque is for the large nut on the rear spindle for a 98. 5 2500 Dana 70 rear differential? I purchased the large socket and need to replace a bad wheel seal in the hub.
Alan
Alan,
My service manual says:
1. Thoroughly clean both axle bearings and interior of the hub with an appropriate cleaning solvent.
8. Install the outer axle bearing.
9. Install the hub bearing adjustment nut. Use Socket DD-1241-JD to install the adjustment nut.
10. Tighten the adjustment nut to 163 - 190 Nm (120 - 140 ft. lbs. ) while rotating the wheel.
11. Loosen the adjustment nut 1/8 of-a-turn to provide 0. 001-inch to 0. 010-inch wheel bearing end play.
12. Tap the locking wedge into the spindle keyway and adjustment nut. Try to ensure that the locking wedge is installed into a new position in the adjustment nut.
13. Install the axle shaft.
14. Install the brake drum.
15. Install the wheel and tire assembly
I hope this helps,
Bud
