Update
Got the axle swapped out last weekend- prep took a lot longer than actual install with an underpowered die grinder. I (for now) bored out the stock plates to take the wider axle of the D80 and used the stock u-bolts. I had to take a torch to the corner of the spring holders on the axle so the u-bolts would fit down the axle tube- the 99MY springs are apparently about 3", while the 92My springs are ~2-5/8 or 2-3/4"
Ujoints were a direct fit.
Shock mounts fit without triming any of the 2nd Gen shock mounts. Guess it has to do with spring holder width. I could squeeze the old shocks like an accordian, so I didnt even bother putting them in.
Driveshaft has 1/2" slack- I'm getting it shortened (so it'll have 1-1/2 to 2" slack) and rebalanced next week.
I had to move the e-brake mount up about a foot to accomodate the "new" cables. It is SOOO neat to have a parking brake now- they had been unhooked in the D70 for some reason.
I plan to get some new u-bolts made up. I think I am going to go with round u-bolts under the axle, and put a piece of 1/2" plate steel on top of the spring mount and torque 'er down real tight. With the springs being narrower than the stock D80 mounts, I think this is the best route for me, plus it keeps it all in line with the K. I. S. S. principle, on which I base my life.
It was a little more work (ok, mainly time) than I anticipated, but nothing unexpected. We used my buddy's font end loader to lift the heavy stuff- axles on and off the truck, back end of the truck itself. I had to use 2 Ford wheels for the time, along with 2 Dodge wheels I got with the axle, and I have a HORRIBLE vibration/ shimmy between 45-70mph. I figure it is one of the Ford wheels (my 90 D350 has a Ford rear axle) bent, or the fact the center hole is a little larger, and may not be lined up perfectly with the center of the axle. but I live 8 blocks from work, so it isnt THAT big an issue at the moment, though I am on the lookout for 2 more Dodge wheels, maybe 3. All in all, I'd do it again. The wheels track is about 4inches wider than the D70 C&C axle I took out, which makes me think it is a D80 C&C axle.
One more question- would it be possible to take the 5/8 lug bolts off the front and put in some 9/16 lugs to match the rear? I realize that would mean 2 more wheels, but at least they'd all match then.
-DP
