Dave Zuber
I bought a Power-Loc from Rieder Racing for my 2001. 5, 4x4, HO. It is the D70-HD carrier with the bolt holes drilled out. Normally, when you replace the carrier it is just a swap. The sizes are very close and you just need to transfer the shims to get very close to the right setting.
In this rear end, the new carrier is about 1/4 wider than the old one. The axle has some 1/4" spacers at the end of the bearings, under the bearing caps. I've heard these called 'thrust wear spacers'. These are to prevent the bearings (when they spin) from wearing the case.
Question: can I just find 1/8" spacers to replace these old 1/4" spacers? Or, do i just throw them out and add 1/8" shims under the bearings on the carrier? Where can I find part numbers for these?
