I am in the process of building a Dana 80 to swap in place of the D70 in my 02 now. I plan on sled pulling more as time goes on. I am keeping the Factory trac lock limited slip carrier and doing a restack of the clutches to tighten it up to save cost for now.
I am wondering what hp level the stock 35 spline axles are good for?
I have been researching 37 spline axles but have found That unless I get an ARB or Detroit locker in 37 spline the only other option is 37 spline side gears for an open carrier that gets welded. My only choice would be an ARB but not sure if they have an E-locker in D80. Not real enthused about all the extra stuff and $$$$ needed for air lockers.
I have found a Yukon 37 spline spider Kit part # YPKD80-P/L-35_R at Randys R&P for the trac lock also but have read lots of stories of poor quality and lack of strength with Yukon products.
So my only 2 options are run stock axles and side gears until failure and chance other damage along with it.
Or spend 1300 now and Get the Yukon spider kit and 37 spline Scheid diesel axles which I have read seem to be about the best. I was in contact with Brad Ingram at scheids yesterday and he is going to see if I have other options for a spider kit for the trac lock.
What are your thoughts?
By the way I like to pull on the conservative side. I like the less agressive tires and prefer tire speed to try to avoid wheel hop. It has worked for me so far, in 3 pull I have 3 wins. That was when I was 150 hp less than what I'm at now.
