I'll check the u-joints but in the past when a u-joint was going I got a vibration at a certain speed. No vibration now. Not throttle sensitive. Maybe a little louder on hard turns at the 40-50 speed where I hear it the loudest. Don't hear much under 30. Over 55mph, engine, tire, wind noise etc. seem to block it out. I'm guessing well over 300hp and I used it quite a bit when I first amped it up. I use Redline synthetic everywhere. In the 370k miles I've probably changed rear-end lube 6 or 8 times(probably not as often as should be changed). Thanks for suggestions. Not looking forward to a total rebuild. John
