Vaughn MacKenzie
My rear axle could use some major service and I'm contemplating whether to rebuild the clutch pack or toss it in favor of something more effective. Mine really chatters and pops, even with Amsoil syn lube and twice the friction modifier I ever put in my previous trucks. I think after 370k it could stand a little servicing.
I know there are a few options out there but not sure what a good reliable HD choice would be for our Dana 80. One thing though, this needs to be done on a reasonable budget.
Maybe I should explain how I would like it to function and you could suggest options. I don't need a full locker, neither do I need fully open diff on the highway. So basically a limited slip that will kick in and grab more when spinning or there is a significant difference in wheel speed. I needs to be something without harsh engagement, preferably one that goes about its business virtually undetected other than making the truck go when it should.
Of all the trucks I've owned I liked the AAM axle in my '03 by far the best. That thing worked right. It engaged well even when the passenger side rear was on a slick surface. It was very smooth and required no modifier. . . I'd switch to one of those in a heartbeat if cost wasn't an issue.
Anyway what would you suggest?
Thanks, Vaughn
Thanks, Vaughn
