If anyone thinks gear oil doesn't need to be changed if you don't tow this should change your mind!
Miles on truck 78808, miles on oil 78808
less than 10000 miles towing/ hauling, (probably less than 5000) Truck gets stomped a bit when I drive but mostly easy highway miles to town with the wife driving.
Dana 80 rear with limited slip.
wear metals PPM
copper 4 (N)
iron 881 (S)
(my test shows normal as up to 200)
chromium 21 (N)
aluminum 6 (N)
lead 1 (N)
contaminants
water %. 0
silicon 166 (S)
(my test shows normal as up to 40)
I don't understand the high silicon, how does dirt get in there? Could it be casting sand still in there?
Has anyone sampled differential oil at low miles and was silicon high?
Does any one have any numbers to compare these to?
How often do you change gear oil with little towing?
The iron # has me a little worried but there's no noise or excessive heat as far as I can tell, maybe just to many miles on the oil. I refilled with a full synthetic, I think I'll pull a sample in 10000 miles to see what it looks like.
Jared
wear metals PPM
copper 4 (N)
iron 881 (S)
chromium 21 (N)
aluminum 6 (N)
lead 1 (N)
contaminants
water %. 0
silicon 166 (S)
Jared
