When it's cold outside,turn the switch,Wait to Start. . whatever it is that kicks on(seeing how I don't know much about these things
) Goes off,fire it up,wait till oil pressure builds up but I've always notcied the amp meter dropping like a rock for a few secs,coming back up,dropping again and after a minute or two it'll jump back up there. . what is making it do this?
Secondly when it's cold,do the above and take off,in 2nd,it will blow a little white smoke,3rd,4th,ease off gas for right turn,when I let off the gas it'll blow white smoke for a few seconds,2nd gear,it'll smoke white for just a split second. Then if I let off the gas a lot it'll smoke for just a second or two. After temp comes up just a bit it won't do it anymore.
Then when it's running,crank it up let everything come up,if I blip the throttle it don't want to run right,the 93 W350,if I blipped the throttle it would blow black smoke. This one seems like it's missing on a cylinder or two and will blow a tiny bit of white/blue/black smoke.
I don't know squat about these trucks,even though I've asked tons of questions I really don't understand these motors at all,just gas motors. I need to grow a big ole pair of balls because I'm moreless nervous about these trucks because I don't know squat about them. The truck has only 86k on the clock and is actual and a older farmer we know had it,hardly ever drove it unless it was to dragging hay or cows around. There is a fellow kind of local,Joey something,that is a CTD nut that people say fellers from Calforina come to let him work on there trucks*shrugs* I'm thinking about taking it to him and let him tweak on the pump and tab the KDB. But otherwise on the motor I don't know where or what squat is. So if you say check this wire or that on this. . I ain't gonna have a CLUE
I've been trying to sell it for awhile and I think it's mostly because I don't know crap about it but I need to grow some nuts :-laf and LEARN Help?
