Originally posted by monkfarm:
My series 2000 was golden colored, not blue. . .
The Amsoil Series 2000 75W-90 is blue in color... if yours is golden colored you have their (standard) synthetic 75W-90 gear oil in your differential.
EMDDIESEL, yes you can use synthetic gear oil with a limited slip differential. I'm currently using Amsoil Series 2000 75W-90 (100% synthetic) in both differentials. As my LSD was setup pretty tight at the factory, I had to add an additional amount of Mopar friction modifier to JUST eliminate the chatter in low speed corners. However, most TDR members have not had to add any additional friction modifier with the Series 2000.
John Treibel
'98. 5 2500 QC 4x4 Sport, Glasstite Vision II, 285 BFG A/Ts on M/T Challengers, Warn 4X Boards, Mopar fender flares & tow hooks, NW Custom s/s-rubber mud flaps and accs. , Mag-Hytec diff. cover & DD trans. pan, Edelbrock IAS shocks, Reese Titan V hitch, SPA gauges (3), Dynamat, '00 Sport grille and headlights/PIAA Super White bulbs, PIAA Dual Sport 900 aux. lights, BD exh. brake, Amsoil Dual Remote Bypass w. trick billet block adapter and Aeroquip Teflon-s/s hoses, Optima Yellow Tops, DD3s and DD TTPM, Aeroquip AQP s/s fuel hoses, tricked out Cummins valve cover, tricked out Banks High-Ram intake manifold and 14 cm2 turbine housing w/Big Head wastegate actuator, ATS 3-piece exh. man. , Banks 4" dia. s/s exh. sys. , DTT 93% TC, DTT custom tuned VB, BD modified trans. front pump (enhanced by DTT), Air Bulldog induction hood (with NACA ducts), plus MANY other trick modifications
NRA Life (Patron) member
