I started noticing a raw diesel smell after shutdown, after checking it out, I could only find a damp spot around the water drain on the fuel filter. Thought it was my return line as these were changed just year before last. Popped the drain a few times thinking the drain valve itself was the problem, not seating. Last week it turned loose, leaking around wire leads. Not just a little, A half of a tank in 60 miles! The replacment is $52. 00. Just a warning for you guys as it could have been worse. My trailer bed and undercarriage is well oil though, waterproofed!
If you do notice a leak, get a new drain on order!
