Dash lighting wiring color
Damn noise!
heated seats
I am wiring up my gauge lighting and I want to splice it into the stock lighting so I can control them like all the other dash lights and the list of color coding I got only goes up to 07, I have an 08 so I was wondering if anyone knew which one it was or I do I need to do it the hard way by breaking out the multi-meter and checking each one of them until I find the right one? Thanks.
Buy yourself an Add-A-Circuit and plug it in to your dash light fuse. Use this for your gauge lights and they will dim with the rest of your dashlights. You don't have to splice anything.
Here you are
CAV CIRCUIT FUNCTION
1 L116 20WT/LG HEADLAMP/FOG LAMP SWITCH SIGNAL
2 E2 20OR/BR PANEL LAMPS DIMMER SIGNAL
3 L115 20WT/YL HEADLAMP SWITCH RETURN
4 E19 20OR/BR HEADLAMP SWITCH DIMMER SIGNAL
5 Z407 20BK/OR GROUND
6 L914 20WT/LG CARGO LAMP SWITCH SIGNAL
7 - -
8 - -
9 - -
10 - -
Thanks Bob4x4, figured it was one of the two OR/BR but w/o knowing what position would have had to tap em to get it right.
