Dash Lights
Clutch life?
Steering stablizers Whats best ? 93 4x4
Gettin a little older and would like to make the dash lights a little brighter for night driving. Has anyone replaced the bulbs with a brighter bulb. If so where to get and what to ask for? Thanks
92 D250 5spd 3. 54 std cab, Banks exhaust,Isspro EGT&Boost gages,18cm Turbo.
67 Dodge R/T
67 Charger
98 Grand Cherokee
97 Stratus
Mopar Only Here
Tulsa 2000 Survivor.
The bulbs in your dash are 194's, the 168's are brighter and use the same socket and are the same size.
BEWARE-extended(6-8 hours straight) use of dash lights with higher wattage bulbs may melt some of the plastic near bulbs.
Proceed at your own risk.
Good luck.
89 w250, 47rh trans, cleaned up exhaust, Dynomax bullet muffer, 3" lift
I have been there (with the melted plastic on a marker light on one of my Toyotas.
I bet cleaning the bulbs and lenses would make a difference - there's gotta be 10 years of dust in there. You could also see if there's room to ad an extra bulb.
I've always hated dim bulbs... (in my Dodge that is)...
91. 5 CTD 4X4, 5" Stacks, Tweaked Pump, 33" Boots (in the summer), Unlimited Slip,
Big, Bad Dodge
Uncle Billy, beat me to that one. i just cleaned mine. Man, what a big difference !!! I can see them very well now... . good tip Mike
http://hometown. aol.com/hotshothauler/myhomepage/business.html 2000, CTD 3500, Air brakes on truck & trailer. 193,000 miles todate. DOT custom built sleeper unit. pulling a 40' G/N flatbed
2000 FL-70 Pulling a 48' low boy. 200,000 miles
Just bought another 92 D-350 215 P-Pump motor and NV 4500 180,000 miles 24 lbs boost all stock For now
