I've pulled my dash many times. After the first time its a breeze. Do a search on "dash removal". I wrote a procedure in there, among many good ones from other members. One important thing to remember is that the antenna connection on the Dodge is not standard. You will need to buy adaptors, and you must be very careful pulling the antenna lead out of the radio, it's tight. Be sure to grab the black plastic plug housing when removing. If you yank on the cable you can pull the coax out of the connector.
