More importantly, there's an entire department of government employees to deal with it. They'll spend more time and money doing the paperwork than you installing the dash.
Why is a B.C. Assigned VIN needed when a dashboard is replaced?
It’s an offence under the Motor Vehicle Act to remove, alter or obliterate any VINs on a vehicle. Under the Criminal Code of Canada, the vehicle operator is presumed to be in possession of a stolen vehicle if the VIN is removed, altered or obliterated. The vehicle may be seized immediately and the operator charged under the Criminal Code.
The dash VIN is the most visible and often-used VIN to identify a vehicle. Law enforcement offiers will recognize the B.C. Assigned VIN as the current and correct VIN, even when other VINs are found on the vehicle.
