Dash Spring clips
These trucks are sweet
Will 295's fit on stock suspension?
While I was removing the dash panel to install my dash gauge pod, 3 of the spring clips fell off the post and went down inside the dash somewhere. I tried fishing them out with a magnet and can not find them. Went to the local dodge dealer to parts and found out that they are not available. They are a factory assembly part only. The panel below the cup holder are the same kind and thay also are not available. Anyone know where I can get some of these clips?????? :{
The dealership would have been my first choice also, but you have already checked. You might could rob the one's from your bottom panel to fix dash panel an then check at a wrecking yard later on for the bottom panel. At least get the dash top back together for now.
Tony
