dash squeaks behind instrument cluster, SB 23-19-00, no help. Found squeak in steering shaft, sprayed with WD40, or as I cal it, mechanic in a can. I sprayed the 'U' joint fwd of the firewall and everything fwd and aft of firewall, squeak is gone. Local dealer is going to replace intermediate shaft. It sure is quiet!!!!!!!!! While I was trouble shoot I found the fuel tank rubbing the frame at fwd left corner, repaired with teflon tape in between tank and frame. Have fun! TBOB.
