Can't help you on the color issue, my blue one came from Dodge last year. BUT I will tell you about my installation modification.
After pondering the insanity that is our dash (attachment screws from the back side!!!... NUTZ) I cut the thing to pieces with a roto zip and basically broke it all out. Here's what I did on the reinstall:
>I Secured the defrost vent duct in the correct position with electric tie wraps to the steel dash braces.
>I drilled through the new dash piece in 3 places on the pass side (where screw are originally designed to come in from the back)and carefully tapered the holes on the finish side to accept tapered screws head.
>I installed clip-on speed nuts on the steel frame behind the NEW screw locations.
>Installed the dash using the normal screws and installed the pass side dash from THE OUTSIDE... NOT FROM the backside of the dash.
It's sorta hard to explain but the finished results are this:
1) The dash installed in 10 minutes.
2) It will take me 15 minutes to remove the dash and install a new one "when" this one cracks.
3) It is easily removed to access other stuff.
I used stainless screws but you could use black. They are small (no. 6 I think) and flush so most people never notice, or don't know the difference.
I added a pic and if you look at the pass side you can see the flush screws. You can PM me if you have questions. You may not want to make this mod but for me, considering future maintenance. . this was the only way to go.
Good luck.
