Dash warning lights question
lug nuts for forged aluminum rims?
Water in Fuel Filter
My low washer fluid light comes on every time I drive the truck. I am also having trouble with the red seal belt warning light. It is also on every time I drive the truck. Yes, my washer fluid is full and I put my seatbelt on. Thanks for any help you can offer.
Do you get the annoying chime with the seat belt light??? If so, the procedure to disable is in the owner's manual. If it's the light only, you could try unplugging the connector at the seat belt and sticking a paperclip in the plug. I'm guessing the washer fluid warning could be disabled the same way.
