I have been trying to track down a very annoying rattle that seems to come from behind the tachometer or within the steering column. It occurs between 2000 to 2300 rpm and is loudest when loaded pulling our fiver. Sounds very metallic in nature like a loose washer or bolt. I have removed the plastic bezel, headlight switch and banged around in there trying to duplicate the noise. I even removed the tach/speedo module to give it a good shake but could hear no moving parts. Poked around under the dash, clutch linkage, brake and gas pedal but every thing appears to be very secure.
I know there is a TSB about a sqeaking dash when going over bumps but I don't think this is it since it is load and rpm sensative (ie stops instantly when I let off the gas. ). The truck is absolutely quiet other times.
This thing is driving me nuts. Has anyone else had a similar problem and if so did you find out what it was? Appreciate any help or suggestions.
Thanks
Ron.
'00,2500,4x4,QC,LB,6spd,3. 54,4wABS,Camper-Trailer packs,BD Brake w/ECM ctrl,Pullrite 20. 5K 5hitch,Tekonsha EnvoySV,12K# Damon Escaper, CobraCB,Flame Red/Silver.
Thanks
Ron.
