Daytime running lights?
Which should last longer, tall and narrow or taller and wider?
Texas Rally is a Go!
I saw a connector in the service manual that said daytime running lights... Does anyone have them? My '01 doesn't... I don't want them, but was wondering what the heck the connector is there for...
'01 2500 SLT+, QC, LWB, 4X4, 3. 54s, AT, every option but running lights! To come: 19. 5"s (?), lift, Line-X, Exhaust brake, 4" turbo to tail, etc...
'98 DUCATI ST2 "Bombed" 944CC with Ducati Performance Carbon Fiber Exhaust, F. I. M. Chip, K&N and "modified" air box.
I saw in my manual that the daytime running lights were on the Canadian vehicles. Anyone help on that? Scott?
'98 ext cab 4x4. Skyjacker 4. 5" lift w/ 36" swampers. 370 injectors, pump done right, psychotty air, HX40 18. 5 housing, JRE stage III fuel plate, McLeod dual disc street clutch-"Mitchellized", ISSPRO gauges, 4" black smoke puffin'-hear me CUMMIN chrome stacks. A member of the best brotherhood around-GLTDR.
**Skyjacker raised**
**Cummins praised**
I used to write electrical sections for service manuals for the big 4 manufactures back in the mid 80's. At that time DRL's were required equipment in Canada. Since then the manufactures have just sold them on all they’re US cars bragging about "voluntarily installing safety equipment" on their cars.
But they sure had a screwed up way of making The DRL's back in the 80's. They had a module that pulsed voltage to the headlights at a high frequency, which made them look dim, compared to normal lights. WHY? Just do like most Europe cars and make it so the headlights come on when you start the car.
  • 98 ISB,QC,5spd,2wd,3:54lsd.
  • 2000 Terry 305G 5th wheel
I commute over a winding mountain road so I tend to drive with my headlights on anyway. The only problem is that the odomoter dims to the extent that it is almost impossible to read during the day. I've debated about putting a manual switch for the odometer dimmer or else buying the daytime running light relay. If anyone knows anything more about this relay, I would like to hear more about it. I have not yet studied the electrical diagrams.
David Dressler
2001 Driftwood 3500 Quad Cab 4x4, 155 inch WB, 5. 9L HO Cummins Diesel (ETH), 6-Speed HD Manual (DEE), SLT+, 3. 54 Anti-Spin Axle, Camper Special Group, Trailer Tow Group, Leather, Sliding Rear Window, Jacob's E-Brake, Rhino Liner, VDO Vision (pyro, boost, engine oil temp. ), Weather Guard Diamond Plate Saddle Box, AND functional Halo light!
"Diesel, it's not just for breakfast!"
The day time running lamp (DRL)is more than a relay it's a module. It's funtions vary from year to year,some run the lites at half power only if the vehical is moveing,others shut down the lites if the parking brake is on,all this is bypassed if you turn on the brights. In other words it's much easier to install a small toggle switch,next to the lamp switch,that bypasses the dimmer circuit when the lights are on. I did this on my '95 because with the lights on in the daytime I couldn't see the display on my clock or overhead console.
Dresslered, on my 00, if you roll the dimmer control for your dash lights, at the top you will find two clicks on the switch. One of them brightens up your odometer and comp. lights for when you drive in daylight with your lights on.
Larry.
Y2K 3500 QC,SLT,4X2,White, 6spd,3. 54 lsd,Banks Stinger +,Pacbrake,Pilar mt. EGT & Boost,Amsoil air filter,all amsoil lube w/BMK-15 filter system,MagTec rear cover,putco boss rbs. w/ rear ext. &flaps,20K reese,100 gal. aux. fuel,fold up T cover,5K airlift bags w/comp. ,ranger 2950 cb pushing palomar 225 amp,phantom radar det.
I had a VW Jetta that had DRL's. One problem, during the day people were always flashing their lights at me. I guess they were telling me to turn them off. Only I couldn't turn them off! It got old. Also, I think that the Canadian trucks are the ones that have DRL's.
99'2500 SLT QC LB 4x4
white/agate, 5spd, trailer, camper, 3. 55LSD, 241HD, cab lights, 3500 tailgate lights, mopar mud flaps, luverne SS nerfs, diamond plate rails, Weatherguard box, Banks 4inch, Isspro Boost/EGT gauges(pre), 265 BFG KO's, ... more to come
yogibear-
Thanks for explaining how the dimmer switch works!
David Dressler
