The dreaded lift pump failure leading to VP44 failure has led me to this website and forum. I absorbed a lot of info in a day or two. Hear is the situation, my 2002 Ram 2500 4x2 Cummins HO has just had the big$ failure at 98000km. Fortunately it is still under warranty, no cost to me. The VP44 replacement was straight forward although there is some issues to correct. Now the LP replacement was completed as follows and I cannot find any reference to this method on the forum. I would like to get members opinions. The engine mounted pump has been replaced by an in tank mounted pump (which I am led to believe is the same pump as the later model Rams). There is a complete factory appearing wire harness and additional fuel pump relay that is plugged into the existing harness and to the new tank mount pump. A block with fuel line fittings replaces the old pump on the side of the engine block to allow the existing fuel lines to be reconnected and routed similar to original. This all came packaged in a kit from Chrysler complete with not bad instructions. According to the dealer this has been around for about six months and they have installed one previously. Other than a minor fuel leak at the tank which they will remedy everything looks good and factory in appearance. Has anyone had any experience with this factory mod? What does everyone think? Is this actually correcting a design deficiency or just moving the problem into a tank full of diesel?
Mr. Mike.
Mr. Mike.
