Would like to get a better idea of the use of DCEP (direct current electrode positive) vs AC for stick welding. What would be the application and benefits / drawbacks for each?
Also, I was welding together some 1/4 x 2" angle iron (not so clean, still rusty) with 1/8 6011 rod. The inside and outside corner joints were no problem, had the welder set on EP at 100 amps and was able to run a decent bead. Had a bit of trouble with doing some T joints though. Kept burning through the end of the angle iron where it butted up to the flat piece I was welding it to. I tried turning down the amperage to 75, but then it seemed to not get good penetration into the flat piece and made a rather ugly tall bead. Next I tried making two passes, first on the flat piece then on top of the first pass to join that into the end piece. That worked better, but still not so well. Any suggestions? Perhaps just more practice?
Cheers,
Sean
Cheers,
Sean
