Yeah, get a boost module and brass boost elbow for that truck. You are de-fueling hard core. You're forcing the truck to work above 20psi (stock fuel and wastegate level), and the ECM is cutting off your fuel flow at 20psi. You're gonna ruin the injection pump that way. I noticed your egt probe is mounted post turbo. You may want to consider installing it pre turbo because at 950deg you're pumping close to 1250deg going into the turbo. If you install a brass boost elbow, you'll be able to bring your egt's down a couple hundered degrees.
You don't have your truck and it's modifications setup right, but if you think it runs okay now, wait until you have the proper boost module and wastegate modifications done and you'll see the truck really perform. If you can borrow those items for a couple hours to test out your power, by all means try it before you condemn the truck too slow that you now need a Comp on it. Seriously... big injectors and a big box is too much for the (95%) everyday grind.
-Mike
