DD boost module on a stock truck.
Boost Plug/Bushing Size?
1/4 thermocouple for SPA gauge?
I got my injectors(IIM) and DD boost module the other day. I decided to try the boost module by itself. Things to note: I have 4inch exhaust and a stock DC air filter and engine. The truck was driven unloaded.
Around town, I saw no loss or improvement in performance. The truck felt exactly the same. This is what I expected. Then I got on the interstate. It could be my imagination, but at WOT on some hills that I am familiar with, the truck seemed to run stronger. Without the module, boost maxed out at 19-20psi and the truck wouldn't accelerate as fast. What I mean to say is it kept gaining speed, but not at the same rate. With the module, the truck didn't miss a beat. I had to lift my foot before the top. However, this is just a seat of pants response. I'm going to try to borrow a G-tech and play with the module on and off. However, I can say in my case that my truck didn't loose power.
Other notables. Before the module, I could hit 20psi, but it was very hard. After the module, I could easily hit 24-25psi. When I was pulling the hills, I hit 28psi a couple of times. Also, in 17K miles I had never seen the filter minder move. After one brief run with the module, it moved about 1/3 of the way down. It is safe to say that with injectors, I will probably need a different filter. Lastly, after driving with gauges for a while, it kind of freaks you out to see the boost gauge just spin right up past 20. I loved it.
99'2500 SLT QC LB 4x4
white/agate, 5spd, trailer, camper, 3. 55LSD, 241HD, cab lights, 3500 tailgate lights, mopar mud flaps, luverne SS nerfs, diamond plate rails, Weatherguard box, Banks 4inch, Isspro Boost/EGT gauges(pre), 265 BFG KO's, ... more to come
[This message has been edited by TradedV-10foraCummins (edited 07-26-2000). ]
As for EGT's, cruising at 70 they were the same. At WOT throttle, I was too busy watching the boost gauge. That is why I am going to try it a little longer. I am driving to Chicago and back this weekend, so I will get to try this setup for about 1200 miles. My main objective with the module alone was to see if it looses power. I REALLY want my injectors in!
As for the K&N, I don't totally trust the drop in. Nothing against the K&N, I think it is the air box. However, I believe the factory filter is thicker at the sealing surface? I have used K&N in all my vehicles before the Cummins. Overall, Psycotty is my first choice, I am just trying to come to terms with the 4. 5 inch hole.
