Ok Bushwakr, since you asked I thought it better to start a new thread on this subject.
Jim sent the pin to me last week. Our met lab found it to be a high carbon alloy steel. So it appears to made from good stuff, DD just missed the heat treat.
We will get some pretty high hardness (Rc 60 ish) and will use our vacuum furnace to be as gentle as possible distortion wise. Distortion is a by product of heat treating, and I'll have to see what happens to the pin before I make a "calling all soft DD pins" request.
(then hope I haven't used up my last favor in our heat treat dept
It is much easier to do a "custom" grind/polish on the pin after it is hardened. The problem is that the pin is ground concentrically, and there is very little diameter left at the top of the cone... it's almost scary.
And for the record, I could not resist installing Jim's pin the night I received it and taking a 3 mile (or so) test run. (so now there's a place to do the custom grind)
Turned my truck into a huge dog. Unbelievable. Boost dropped from an easy 25+ to barely 18 ... . and that was after waiting for soooooo long with my foot thru the firewall.
EGTs were non-existant, as was the smoke that I get with the stock pin when I nail it at low rpm.
My stock pin is a 75 as I recall, and I think these were the pre-intercooled fuel pin.
Jay Leonard
Jay Leonard
