If i add DD3's, boost fooler, guages and an air filter w/ no other mods what problems will i run into? This should put me around 350hp at the wheels this is about all i want. would this be a viable option without using a box and raising rail pressure. Is running dd'3 going to raise rail pressure (it should not). Is there a way to get around buying DD's boost fooler for three hundred bones? I figure i will need about 35#'s boost and stock turbo should handle this and so should the 6 speed i have. I figure this is probably the limit but if i go any further i will have to spend big bucks on the transmission and 350 hp will be where i want to be anyway. are the dd3's as dependable as dd2's? will egt's be a problem w/ dd3's only? i know this is alot of questions but alot of guys dont want to raise rail pressures but want to get to 350hp.
