DDII HP AND BOOST NUMBERS
Stock Lift Pump Info
Paintless Bodywork
Ive got a TST PM3 and at WOT under load I push 30-32 lbs. boost.
Just wondering what kind of boost and HP numbers I will achieve by installing DDII's or DDIII's.
Anyone using the Bully Booster step 5 injectors? They claim 200 HP increase!:D
i don't thikn we are in Kansas any more 777....
Hey, you live in Grapevine... . are you coming to the dyno day? A great chance to figure out what hp #'s your at, and then go from there. I know your over me, but rumor has it Cord is going to break at least 520. :eek: Don't you want to be a part of that?
Anyways, I have nearly the same setup, and I'll be going with DD3's for my daily driving. With this setup, you might want to look into a Piers HX35 too. That should put you around 425-450hp.
Andrew
777,
I have both the DD2's and a PM3 on my '00 ETC/stick truck which is just like yours.
My DD2's alone hit 32psi with the stock ecm. When I installed the Torqus Maximus ecm I now hit 33psi. With the DD2's and the PM3 fully cranked, I hit 44psi of boost with the stock HX35/12cm and a straight piped 3" exhaust. On the dyno it showed 406hp & 870tq.
-Mike
pegged gage
With dd2s and P. E. turned up to 3 I can peg my 35 p. s. i. gage:eek: . Probably hitting close to 40... time for a bigger gage;) . Doug
Lewisville Dyno Day
Eric,
The Dyno Day is at 9 AM Saturday January 12 th 2002
Speedworks
414 Holfords Prairie Road
Lewisville, TX 75056-9581
Phone: (972) 395-9844
Looks like there is going to be a big turn out. See you there!
:cool:
777, I have the BD step 5's. With the 5's and the Edge EZ box, I can hit about 43 psi's of boost with the HX40 in 4th gear, 5th or 6th gear and a hard romp on the go pedal take the boost right up to 45 psi's, which is my wastegate on the 40. That's with the TST box off. Just hit the wastegate faster with the TST on :cool: .
Scott W.
