Looking for injector advice. I like to do things once, getting it right the first time if possible. I'm planning to swap my 160 pump for a 215. Stock turbo is good so i don't want to touch it right now-later when budget allows. Looking for 350 hp now but i'd like to be upgrading to parts easily capable of 500 hp later on without further, expensive modifications. I want to buy a set of injectors i know i'll be satisfied with.
Ross at DDP says stage 3 injectors should maintain safe EGTs and controllable smoke if i leave the 215 pump stock. I also plan on advancing the pump to 15. 5 degrees. Aside from safely making the truck more powerful and driveable, i want the best fuel economy possible.
Can i get away with stage 4 injectors with a stock turbo in the mountains, or do i need to stick with stage 3s? If i slide the cam plate all the way back with stage 4s and my stock turbo, what sort of power and EGTs should i be reaching? What might i expect for fuel economy with either set in a 10,000 lb truck having 35" tires and 3. 73 gears? I know i'll have to watch my gauges if i tow until i go to a bigger turbo.
Ross said that the 215 pump only needs a plate, GSK, and stage 4 injectors to make 600 hp. He also says the stage 3s will support 500 hp. He claims DDP stage 3s are bigger than anything from Bosch. I realize my turbo will be holding me back, but i'm spending too much as is.
I have a 5" exhaust with a muffler behind a 4" downpipe, an open element conical air filter, and will be reconnecting my water/methanol injection. I imagine those items should help me maintain EGTs below 1,500. I hope to stay under 1,200 degrees climbing hills in the mountains.
I know a lot of you guys are running DDP injectors and am anxious to hear your opinions and suggestions. I plan to order this week. Bottom line, should i go with stage 3 or stage 4 injectors?
Thanks,
Matt
Thanks,
Matt
