Dave Zuber
Yeah, not supposed to put engines here, but it doesn't fit in the other thread for pickups.
I have a 2023 3500 C&C with the de-rated 800 fl/lb 6.7. It really has a 'flat spot' in the power until 1600 rpm. Tow haul doesn't help and many times i have a dead pedal. Rolling at 13k lbs gross. My 2021 with the 875 ft/lb engine is much more peppy, it will pull strong from 1200 on up, even when towing at 14k plus gross.
Question: does it get better after break-in? Only 18k miles now with no changes since new. Some way to fix? Can I get a reflash with the pickup map?
