I need to make my throttle not so responsive. the problem i have is it takes very little throttle to rev the truck. driving its not a problem. but now that winter is here, i have started using my high idler. i can only adjust it to about 1100 RPM's anything above that when i activate it, it will rev the engine up past 3K and slowly return it to what the idler is set at. I have a 0 plate. i have the plate about 2/3rds forward and the initial screw is set to limited smoke. i have a 4K GSK, 191's and custom injectors the equivalent to 370's. the truck runs like a scalded dog but has too sensitive of a throttle. these injectors dump too much fuel at idle is what i think is part of the problem.
I'm thinking move the plate back a tad first. what then?
thanks,
Todd
thanks,
Todd
