My 01 -6speed just started this with no warning. when you take off the accelerator pedal seems dead up to around 1800 rpm, the only way to get any speed up is by up-shifting to a higher gear,but no power,20 mph in 2nd or 3rd gear, floor it , nothing happens, after gradually coaxing it to 50 mph in 5th gear it will respond somewhat normally, it just acts like it is starving for fuel at low speed. It still pulls good on hills at higher rpms. Could this be a MAP sensor bad ? I've reset the apps, cleaned the AIT sensor, which was not dirty, checked air filter, intercooler hoses, new fuel filter, the intake air heater seems to be working ok, the truck starts fine. This problem seems to improve somewhat after you drive 15 to 20 miles,but it is still noticable enough to let you know you need to keep your foot in it. The truck has not thrown any codes via the ignition on 3 off 2 method since it started doing this about 2 weeeks ago. I know this is rather lengthy but I described my problem the best I could.
