Archived Dead lift pump?
Archived Wide open throttle after lift pump change
Archived transmission is dead
Own a 98. 5 24V Cummins.
Have just changed out fuel filter and doesn't want to prime.
I have opened test test port on the fuel cannister lid and have bumped the starter several times. Can hear the lift pump running when I do this. Finally tried opening the banjo bolt on the input
side of the lid... no fuel coming out when I bump the starter.
Is it safe to assume my lift pump is a goner?
Thanks,
Fred
I Agree w/ Larry....
That is exactly what mine did as well. The first time I changed the filter, it took about twenty "bumps" to finally get it started. I should have measured it then. It would have saved me the towing cost when I changed the filter the second time. ;)
TMC
Thanks guys,
Only have 80K on truck so will call a dealer or two in the A. M.
Hope they don't give me too much grief.
And all this time I've been worried about losing 5th gear!
Final on lift pump --
Dealer replaced @ no charge. They squeezed me in even though they were extremely busy. Kudos to Todd (service manager) and Timberline Dodge... good guys!:)
Fred
