Engine/Transmission (1998.5 - 2002) Dead Pedal
1998. 5, manual trans, not my puller, that is 100% stock (not mine:D), the accelerator pedal is very touchy for the first 1/2" then is dead from then on. The truck only runs about 1400rpms. Only present code is the p1689. when I first scanned codes it had a crank sensor code but has not come back up. Sounds like the truck has been doing this for a while now The RPM gauge does work so I not sure the crank sensor would be the problem. Any ideas. Also I reset the apps with a volt meter and did not help.
