Gentlemen, I had a little problem yesterday on the way home from work the engine would surge at idle and act like it was going to die, also had little less power. Later last night I shut it off at sonic and it would not start. Had friend pull start and limped back home, Is this a load of bad fuel that clogged my filter or the injection pump going out? Fuel pressure was normal 14psi @ idle and 10-12 psi @ 70 mph. Thanks.
