Dealer, adjustable ball joints, fluid leak, dent, mad.
General brand Tire Recall/Problems?
Bringing in the raines, Lets stop this truck
Dealer- took my truck to the dealer to have my front end finally aligned correctly after 4 alignments with hard pull to the right. Adjustable ball joints - is what finally corrected the problem, my truck now steers straight down the road, wooohooo. Took a year to get this done. Adjustable ball joints from Ingle products. Although dealer states they had to remove the spindle and caliper every time they needed to make an adjustment to get it aligned, because the ball joint needs to be removed each time??? Fluid Leak - now my freeking front axle is leaking like a faucet. Truck only has 18k on it and there was a big puddle of dif fluid under the axle this am. They obviously damaged the seal while performing there 5 star work. Was treated like s*&% by the asst service manager when I took it back today. Threw his arms in the air and walked away from me when I tried to explain the problem. Told me they could not of caused that, that's not the area they were working on. DENT- another freeking dent in my truck that makes 3 now that need body work. Already spent a week in body shop for last dents they put in it... . Now they need to fix another one. These jerk offs are careless pieces of S*^%. I'm fed up... ... ... Sorry just venting on you guys again. Figured since there was a few positive dealer stories lately had to ruin it. Don't go to CROWN DODGE IN VENTURA CA. if your life depended on it... ... :mad: :mad: :mad: Sorry so mad... ... ... ,more like frustrated... ... ...
