thanks for the help guys,
I showed them what the numbers where. they were just reading the first numbers 5 to 7 psi while cranking,thats why they said it was good,as you read on which they did not ,it says 10 psi at idle min. 5 psi across fuel filter. 6 in/hg max vac in fuel line.
even then they still called dodge and dodge said replace it.
so they ordered the part.
what the plan was, was to let them buy the part,and then when I go see scott at mass diesel on the 15th,he would move the new pump back where it should be. thanks again mike
