I have been have an ongoing symptom of what sounds like a “machine gun” that can be heard from the engine. It is also felt as a sort of “pulsation” that is consistent with the noise. It is felt and heard regardless of engine or vehicle speed. I feel it most when traveling at a slight up hill condition in 4th gear at about 45 MPH. The lift pump replacement has less than 1000 miles, the truck has 65,000 miles. The valves were adjusted when the lift pump was installed.
It smokes upon start up or after sitting for around 4 hours. It is white smoke and the truck shakes and rattles VERY harshly for about 10 seconds until it settles down to which the symptoms as described above take hold. There are no codes present as shown on the dealer instruments.
The dealer says that it is carbon build up in the combustion chambers and on the valves. We tried the injection cleaning service as a first try to fix this. It did not improve the symptoms at all. The dealer is now proposing to remove the head and manually remove the carbon deposits. I am assured that this is the problem and it will fix it.
I am somewhat concerned about taking this drastic course of action. All I know about diesels is from what I have learned here. When the lift pump was replaced it had been running the engine at zero PSI for around 4 – 6 weeks but I have been assured that the injection pump is fine.
Has any one heard of anything similar to what I am describing? Is this the correct method of resolving the problem ar is there a less drastic measure that could be taken? I could really use the input from knowledgeable members on this one.
