Lift pump replaced truck is running fine. When I pulled the codes the fan speed code showed up. I wonder if the shutdown of the engine when the lift pump failed could have injured the fan clutch.
Here's what is going on:
Engine cold fan does not spin freely feels sluggish about 80 of the circle then loosens, but still had drag, when cycled by hand.
Fan locks up upon start then after a minute or so releases and rotation slows. Locks in when ac is switced on.
I'm thnking it's time for a clutch even though there is no bearing noise I believe when cold it should free-wheel when not running.
I wonder if the sudden shutdown (@ about 1500 rpm) could have hurt the bearings, or maybe it is coincidence.
If I need one which should I consider for quality dorman, hayden, four seasons?
Any other test I should consider before tossing $175 at it?
