Just did my first DEF last night, Used Peak 2-2/2 gal from Walmart.
Gauge went from 20% to 80%, so accuracy not too bad.
But I was the dummy trying to figure out how to connect the Peak spout to the jug and then the little rubber piece. Of course I installed the rubber backwards and dripped some DEF even with my finger over the end.
Why is it that clarity comes AFTER you screw up? Duhhhh! A little pic on the Peak box would help people like me!!! #@$%!
OK, just in case there are others like me, insert the rubber into the hole in the side of the nozzle cap so the oval open end is OUTSIDE and the flat part is inside. (Hint: allows air to enter jug after is have partially collapsed!)
Duh, dummy #2, Noticed I misspelled DEF in Title of post and cannot edit it
Tom
Tom
