Decifer VIN Information...
Can't Open Engine Fuel Filter Housing
Tire advice please
On the following VIN number.... would one of you with a computer please share which Automatic this vehicle has... and what the rear end ratio is...
3C63R2GL9DG582302
My other question on the 4th Gen trucks... is that on my 3rd gen truck my 3500 has a set of overloads above the standard spring set... and this helps when towing... This truck doesn't have that additional helper set.... is this now the standard on the 4th gen trucks... maybe because of a reprogramming of the existing spring set...
Also I didn't see any kind of ON/OFF for the exhaust brake feature... is this now part of the software programing of the 4th gen... or is this an option that has to be purchased and added.... I assume that these trucks still have the variable turbo that will function as an exhaust brake..
One last thought... I see this truck has what looks like only an am/fm radio.... and didn't realize that the factory still did that and not included a CD Player.... your thoughts on this.... is there a plug and play option to change this easily...
And writing this I'm realizing I need to read a lot more posts on the 4th gen trucks...
Thanks for your insight...
Cant help you with the VIN stuff but CD player is optional in the center console. There is a USB port there too and a Aux input. The exhaust brake is controlled by switched under the radio in the center stack. I guess your looking at a Tradesman?
Jim, I tried for about an hr but could only get generic info from your vin. As for helpers, my 15 srw has factory GN hitch and an Aisin and has no helpers. Sorry I'm no more help.
[TABLE="class: table, width: 940, align: center"]
[TABLE="class: table, width: 940"]
APAS
Monotone Paint
AR9S
Single Rear Wheel Group
BCNS
730 Amp Maintenance Free Battery
BNBS
Electronic Stability Control
BRTS
Anti-Lock 4-Wheel Disc Brakes
CB9S
2nd Row In Floor Storage Bins
CGDS
Front Height Adjust Shoulder Belts
CGSS
Supplemental Side Air Bags
CG3S
Advanced Multistage Front Air Bags
CJ1S
Supplemental Frt Seat Side Air Bags
CKJS
Black Vinyl Floor Covering
CSPS
Driver/Passenger Assist Handles
CTLS
Base Door Trim Panel
CUES
Rear Underseat Compartment Storage
CV3S
Urethane Shift Knob
DJNS
6,000# Front Axle
DRQS
11.50 Rear Axle
DSAS
Anti-Spin Differential Rear Axle
GACS
Tinted Glass Windows
GBBS
Tinted Windshield Glass
GJDS
Rear Fixed Window
GNAS
Rear View Day/Night Mirror
GPGS
Power Black Trailer Tow Mirrors
GXXS
Sentry Key Theft Deterrent System
HAAS
Air Conditioning
HGBS
Dash Liner Insulation
HGFS
Floor Tunnel Insulation
JATS
Instrument Cluster w/Display Screen
JBFS
Instrument Panel Black Bezel
JCBS
120 MPH Primary Speedometer
JHAS
Var Intermittent Windshield Wipers
JJBS
Dual Note Electric Horns
JJJS
12V Auxiliary Power Outlet
JKYS
Power Accessory Delay
JPBS
Power Locks
JP3S
Pwr Front Windows, 1-Touch,Up Down
LAZS
Vehicle Information Center
LA6S
Incandescent Tail Lamps
LCHS
Rear Dome Lamp
LMES
Halogen Quad Headlamps
LMGS
Automatic Headlamps
LPES
Cargo and CHMSL Lamp
MBNS
Black Rear Bumper
MB1S
Black Front Bumper
MCMS
Body Color Headlamp Filler Panel
MDAS
Front License Plate Bracket
MENS
Front Wheel Spats
MFFS
Black Grille
MGAS
Ram's Head Badge
MNAS
Black Door Handles
MT7S
Ram 3500 Badge
MXBS
Front Air Dam
NFXS
32 Gallon Fuel Tank
NHMS
Speed Control
NMCS
Heavy Duty Engine Cooling
QW7S
Bright White Clear Coat
RA1S
Radio 3.0
RCGS
6 Speakers
SBES
Power Steering
SCFS
4-Spoke Steering Wheel
SFBS
Front Heavy Duty Shock Absorbers
SGBS
Rear Heavy Duty Shock Absorbers
SHAS
Front Stabilizer Bar
SUAS
Tilt Steering Column
TBBS
Full Size Spare Tire
TBMS
Tire Carrier Winch
TCNS
LT275/70R18E BSW All Season Tires
WBNS
18X8.0 Steel Wheels
WKNS
18 Steel Spare Wheel
WL1S
Single Rear Wheels
XA8S
Non Adjustable Pedals
XBSS
Pickup Box
XEAS
Tow Hooks
XFKS
7 Pin Wiring Harness
XFRS
Class V Receiver Hitch
XFUS
Trailer Tow w/4-Pin Connector Wiring
XJJS
Locking Tailgate
XJ8S
Body Color Fuel Filler Door
XLNS
English/USA Language
X8ZS
Seat Parts Module
X81S
Instrument Panel Parts Module
X82S
Door Parts Module
X83S
Front End Parts Module
X88S
Tire Wheel Parts Module
YAAS
Build To U.S. Mkt. Specifications
1ALS
U.S. State/Local Bid
170S
Zone 70-Phoenix Arizona
5AXS
Crew Cab
5BSS
D2/6333 Vehicle Family
5I2S
Two Wheel Drive (2WD)/(4X2)
5I7S
Price Class L
5LAS
2013 Vehicle Specifications
5ZFS
8 FT. Cargo Box
5ZNS
3500 Series
594S
Vehicle Order Tracking
6USS
U.S. Specifications Label
648S
Washington Ship to State Code
948S
Washington Sold to State Code
Optional Equipment
Code
Description
Code
Description
Code
Description
*TX
HD Vinyl 40/20/40 Split Bench Seat
-X8
Black/Diesel Gray
BADP
180 Amp Alternator
CBEP
CDRP
Front Armrest w/Cupholders
CFMP
Rear Folding Seat
CJ2P
Supp. Side Curtain Frt/Rr Air Bags
CUYP
Storage Tray
DBAC
All Automatic Transmissions
DG7
6-Spd Automatic 68RFE Transmission
DMRP
3.42 Axle Ratio
ETK
6.7L I6 Cummins Turbo Diesel Engine
GVBC
All Vehicles W/Power Mirrors
GXM
Remote Keyless Entry
JP8P
Manual Adjust Seats
LEBP
Ext. Mirrors w/Supplemental Signals
LECP
Exterior Mirrors Courtesy Lamps
LE4P
Black Exterior Mirrors
MPGP
Cummins Turbo Diesel Badge
MPPP
Rear Wheel Spats
NAS
50 State Emissions
NENP
Diesel Exhaust Brake
NHBP
Transmission Oil Cooler
NHJP
Exterior Mirrors w/Heating Element
NHNP
Electronically Controlled Throttle
NZCP
Current Generation Eng Controller
PW7
RAAC
All Radio Equipped Vehicles
RDDP
Fixed Long Mast Antenna
RSUP
Audio Jack Input for Mobile Devices
RSXP
Remote USB Port
RS6P
Media Hub (USB, Aux)
R01P
All VP1 Radios
TZFP
Firestone Brand Tires
WLYC
All Steel Wheels
WMJP
Center Hub
XALP
Selective Catalytic Reduction (UREA)
XBNP
Tip Start
XHC
Trailer Brake Control
YG4A
5.5 Additional Gallons of Diesel
ZHKP
Spring - Left Front
ZKSP
Spring - Left Rear
ZWKP
Spring - Right Front
ZYSP
Spring - Right Rear
Z3HP
GVW Rating - 12000#
2FA
Customer Preferred Package 2FA
2TAA
Customer Preferred Package 2TA
3AH
Price Protection - Code H
4DH
Prepaid Holdback
4EAA
Sold Vehicle
4ESA
Delivery Allowance Credit
4FA
Special Bid-Ineligible For Incentive
4FMA
Fleet Option Editor
4FT
Fleet Sales Order
4HF
Special Scheduling Condition VI
4KA
Special Bid Handling
4ZA
In Plant Painted Cargo Box Tracking
42EP
Saltillo Truck Assembly Plant
875P
United States Region Group
894P
NAFTA Region
Special Equipment
Code
Description
Code
Description
Code
Description
No Special Equipment Available
Dealer Installed Equipment
Code
Description
Code
Description
Code
Description
No Dealer Installed Equipment Available
[/TABLE]
[/TABLE]
Bob4x4.... and guys...
Just what I was looking for... will know in 24 hours if I own this truck...
Thanks for your help... I assume that I'll be able to find/upgrade the sound system without much difficulty..
Bob, is that info available to anyone or just dealer employees?
The identical information, sans sales codes, can be had by anyone by copying & pasting the VIN to the end of this link :
http://www.ramtrucks.com/webselfservice/BuildSheetServlet?vin=3C63R2GL9DG582302
I'd imagine what Bob4x4 posted is ran via a dealer summary report of some kind, since it is detailed with actual sales codes.
Good luck on the auction, jelag.......a bed, a little cab repair work, and there'll be lots more miles left in that truck!!!
I got the same type of report from my friendly Dodge/Ram dealer. They called it a "Star Network - Vehicle Information Report". They wanted to see the owner's registration (title) before they would print out a report. For some reason they want to make sure that you're the registered owner.
If you show owners name address etc it becomes a privacy issue
