Decisions and clutches
Which Brand of Universal Joints?
Tonneau Cover
Well my clutch is starting to slip. Now I must decide to either put in a better clutch or lower the horse power[yeah right]. Maybe I should ask the wife? #ad
The other decision is should I use Centerforce or the Dual disc?
Paul A. Schmidt
95, 4X4, SLT 2500, 5 spd. , 4. 10, 270 hp. ,675ft. lb. TST, AFC spring kit,215hp. injectors, Pacbrake, Walker muffler,
GearVendor O. D.
Eastern PA.
Paul what kinda muffler do you have P/N? Is it louder than stock. Thanks Tom F
97 Ram 2500 4x4 Driftwood 5spd 3:54 E-brake Isspro,boost&pyro guages 25,500 miles
Paul, I've seen your posts and have a relitive guess of your hp #'s, I bought a centerforce from 4wheel part after calling centerforce to get the part # and talk to the tech to see how much power it would hold, he told me it will hold over 1050lbs of torque at the rear tires and they had done it, sold(495. 98), I bought it installed it, broke it in and went wheeling, it lasted 700 miles and 9 days, the friction material on the front desintagrated leaving only the rivits and corners, yah it got hot but nothing more than the stocker had that lasted 113k, so I sent it back(30) with the knowledge that everyone with the same experiance had got nothing back even with the "90 day" warranty, so I baught the Jim Leonard dual disc for 1200, its been great, acctually I had two diffent disc because the first set(pulling) I broke the input shaft and bent the discs and the presant(street), it has very little chatter and less peddle pressure than stock and holds great with all I throw at it. I don't want to see you spend 1900 for a 1200 dallor clutch but its your choice and my opinion and bad experiance,Adam
'96 2500 4x4 3. 54 traclok,billit grill,blue head lights,tenzo blue fog lights,clear tail lights w/red bulbs,chrome front & rear dif covers, alumium bed rail covers and tailgate cover,3" stageII lift,35"BFG M/T's on alumium rims, Kenwood sterio system,tinted windows,westach 60lb boost/egt guage,NOS,bullydog LPG injection,360 degree K&N,"tweaked" pump, 4" exaust w/ flowmaster and a 5" tip,Jim Leonard dual disc clutch, 121k,best performances to date=14. 35@97. 8mph(2wd)Weds Mar22,TuesMarch21 351Hp on the motor,394Hp w/ NOS,428Hp w/ NOS and LPG on, You know the rest,yep brand new pherd there tonight, people came and talked tome,said the book says it make 400hp,LOL, running 22. 4 et, HeHe. '98 Prostreet FXR,Kenny Boyce,96" S&S,Thunder Header,Metzler,12. 10et@105mph
No I would stay away from the centerforce. It all depends on how much you want to spend and the way you use you truck. I tried a single disk pulling clutch and can't get it to hold up to the type of holeshots that I'm doing. I'm looking for 500hp and i want no slip when launching at the line. I'm now getting the Mccledo pulling clutch.
Tom
96 2500 4x4 nv4500 3:54 slt 3"body lift 2. 5" suspension by skyjacker dual steering stablizers dual front shocks 267/75/16 street tires 36/12. 5/16 swampers for mud silencer ring lost 5" pipe borla KN round style filter JRE stage 2 kit 330/730 JRE afc spring kit boost and pyro gauges
Tom F1
I am running a Walker or NAPA #21468 muffler.
Adam
I am somewhere around 300 hp. at the rear wheels. I do no know what the torque is.
Thanks for the replies.
Paul A. Schmidt
GearVendor O. D.
Eastern PA.
We have some folks lining up for a group purchase of the McCleod dual disc. Anyone interested get on board. The savings is likely to be only 150 bucks but I'll guaratee you this sucker will hold #ad
I posted the topic on the 24v forum. Lets keep it at the top and next week I'll call George to see what gives.
Thanks HVAC. Just what I need when I need it!! #ad
Paul A. Schmidt
GearVendor O. D.
Eastern PA.
